Is it possible 4r70w
That's what we need one of the transmission experts for. All I can tell you is the 5.0 and 4.2 V6 have the same bellhousing pattern, the 4.6 and 5.4 Tritons are different. Also, RWD and 4WD transmissions are not interchangeable.
As long as the main case connector is white like yours.
You can use a 96-97 4r70w with a 95 and older computer, but not the other way around. The newer TCC solenoid is backwards compatible. The older TCC will draw too much current and burn up the newer computers.
D
D
There is no "aodew" - there was the AODE and there was the 4R70W. There was also the E4OD.
I don't think a van transmission will fit, sorry, I misread your post.
You need a 4R70W out of a 94-96 2wd F150 with a 5.0.
