Door sticker info
Old Aug 6, 2018 | 04:41 AM
Angie Tadlock's Avatar
Door sticker info
I've got a 2008 f150 5.4 2 wheel drive on door jam sticker under transmission it has a Q what transmission is that Ive got 14 bolt transmission pan which I've seeneans aod, looking up parts I've been told 4r70w and e and I've also been told 4r75e and w and I'm just confused and frustrated at this point can anyone tell me what Q means on door sticker under transmission so I know what I'm dealing with please
Old Aug 6, 2018 | 08:08 AM
Roadie's Avatar
4R75e is what I found after googling
Old Aug 6, 2018 | 10:45 AM
Mark Kovalsky's Avatar
The last AOD was built around 1992, so that's not it. The last AODE was in 1995, so that's not it, either. The door code for 4R70W is U, and I'm pretty sure the 5.4L had the 4R75E in 2008.
Old Aug 8, 2018 | 05:54 AM
Thank you when I looked up aod transmission it only pulled up late 80's early 90's so that's what I figured and couldn't find what Q ment any were so thank you for your response.
Old Aug 8, 2018 | 05:57 AM
I couldn't find Qnany were but every time I looked up truck it would tell me 4r75e and the next one 4r75w do u know if there is a difference in the 2 or can I use either transmissions
Old Aug 8, 2018 | 08:05 AM
Roadie's Avatar
This has been discussed before. I googled and found these links.
https://www.google.com/search?q=diff...hrome&ie=UTF-8
