Hello yall
Old Mar 6, 2018 | 02:00 PM
Mine's Avatar
Hello yall
I'm new to this formal. I have a 1997 f150. I replaced the transmission in it. The drive shaft is 2"to long. The transmission that was in it had a hump in it the one I put in it is flat they are both 14 bolt pan. Can someone tell me something.
Old Mar 6, 2018 | 06:35 PM
I would say get the driveshaft shortened.
Old Mar 6, 2018 | 07:43 PM
Mine's Avatar
I need to know what kind of tranmission I put in the truck so I can change the filter.
Old Mar 6, 2018 | 08:11 PM
It's probably a 4R70W.
Old Mar 6, 2018 | 09:47 PM
What engine do you have? What is the TRANS code on the door jamb sticker? Is yours 2wd or 4wd? Don't you have any idea what the replacement transmission came out of?
Old Mar 6, 2018 | 10:10 PM
Mine's Avatar
That was the same type of tranmission I took out. It has Rf-f4-ap7006-ac on the tail shaft. I would think if it was the same type of tranmission I took out the drive shaft would work.
Old Mar 6, 2018 | 10:14 PM
Can you take pictures of what you are talking about?
Old Mar 6, 2018 | 10:17 PM
Mine's Avatar
I found the transmission on Craigslis. The guy said it came out of a f150. The linkage is different and also wiring harness is different.drive shaft is to long. I really don't won't to cut drive shaft.
Old Mar 7, 2018 | 07:37 AM
JCR 56's Avatar
Sounds like you might have bought the wrong transmission for the truck. You don't want to mess up your driveshaft and find out the transmission won't work.
Old Mar 7, 2018 | 08:44 AM
Darrin Burch's Avatar
I'll second that. It's not the same transmission. Don't do that.
D
Old Mar 7, 2018 | 10:21 AM
Can you answer my questions, please?
Old Mar 7, 2018 | 03:19 PM
Mine's Avatar
I don't think I will cut the drive shaft. I believe in doing it the wright way. I found another tranmission at scrap yard. It is in an 1997 expedition v8 4.6. the same motor I have.
Old Mar 7, 2018 | 03:23 PM
Mine's Avatar
It has Rf-f4-ap7006-ac on the tail shaft. If that helps anybody. Also has pke-f2 on plate on passenger side.
Old Mar 7, 2018 | 03:34 PM
If your truck and the Expy are both 2wd or both 4wd, it should work.
Old Mar 7, 2018 | 03:50 PM
Mine's Avatar
It bolts up to the block. But wiring harness is different. Linkage is different and can not hook up drive shaft. Drive shaft is 2"to long
