Trans Fault Codes
Old Dec 18, 2017 | 03:38 PM
RyanA97's Avatar
Trans Fault Codes
2005 F150 4.6L, 2wd. Truck started bogging down in 1st/2nd i believe, over-revving and having a hard time shifting in and out of 1st, 2nd, and possibly 3rd. A Trans Fault message displayed. Had the truck scanned and P0731 and P0732 were the codes. I lost over drive about 2 years ago (see previous threads) due to the notorious retaining ring breaking. Anyways, do you think this possibly a faulty speed senor or TCM? Or should I prepare to replace the trans? I won't be wasting my money with a rebuild. Thanks Guys!
Old Dec 18, 2017 | 05:27 PM
RyanA97's Avatar
130K on the truck
Old Dec 21, 2017 | 09:13 AM
Mark Kovalsky's Avatar
It's rarely the computer. If it were a bad speed sensor you'd have a code for a speed sensor. Most likely this is a mechanical problem inside the trans.
If you're not going to waste money on a rebuild, then your only other choice is a used trans, right?
Old Dec 21, 2017 | 09:36 AM
Roadie's Avatar
https://www.obd-codes.com/p0731
https://www.obd-codes.com/p0732
