2000 F150 4x4 5.4 Stall Speed/Slippage?
Old May 22, 2013 | 12:25 AM
Devilmanak's Avatar
xxx
xxx
Old May 22, 2013 | 12:27 AM
Devilmanak's Avatar
xxx
Old May 22, 2013 | 12:56 PM
Veteran: Army
well, when you're done hurting the transmission feel free to return it to stock line pressure and increase the line pressure mechanically via a "shift kit" ("seperator plate" or "j-mod")
you failed to tell us what gears the truck is equiped with and what size tire you are running...
how long have you had the line pressure cranked up via the pump? if it's been too long then you might be in need of a new transmission as nothing can help a failing pump besides a rebuild
Old May 22, 2013 | 03:33 PM
Devilmanak's Avatar
xxx
Old May 22, 2013 | 04:47 PM
Veteran: Army
Originally Posted by Devilmanak
Just doing what two transmission builders told me to do, in the order they told me to do it, thanks for being so pleasant.
well they are clueless about the realities of transmissions in these trucks
so now we'll wait on you to provide us more info since we can't see thru the internet
*edit*
if you wanted to hear what you want to hear, next time feel free to post that so we can oblidge VS telling you what you need to hear
Old May 22, 2013 | 05:27 PM
Mark Kovalsky's Avatar
2000 F150 4x4, 5.4l. Dog on the bottom, won't chirp a tire to save it's life. I just read that the 5.4 had a 1300-1500 stall converter? Is that right?
Not from the factory. Ford has never used a converter with a stall speed that low.
I just did the brake/gas test, and got 1650.
That's still low. I would expect the stall speed to be closer to 2000.
Either the engine is low on power or the torque converter has failed and lost it's torque multiplying abilities. If the one way clutch inside the converter fails this will happen.
My other issue is that, although tranny fluid smells/looks great, I think I may be getting some slippage in the tc?
I know you are getting slip in the torque converter. That's how a torque converter works. Any torque converter that doesn't have any slip is called a clutch.
it almost feels like the TC is slipping until it locks.
Once again, that's how a torque converter works. It slips until it locks. This is how it is supposed to work.
Was also told that the tranny has electronic controls to make it like this, so I am lost.
Torque converters were like this before electronic controls.
