1997 f150 transmission interchange question
Nope. The 4.6/5.4 Triton V-8 has a different bellhousing bolt pattern from the V-6. The V-6 uses the old Windsor bolt pattern.
You need another 4.2 transmission, and it has to be from the same drive system truck (2wd or 4wd). If you have a 2wd, a transmission out of a 4.2 E-van should work.
