Idle surge when shifting from park to reverse or drive
I hope someone has seen this problem. 2001 F-150 71000 miles., 5.4 liter 4R70W trans.
When shifting from park to revers the engine idle surges. 200-300 rpm approx. When going from reverse to drive 100-200 rpm. Doesn't matter if it is cold or hot. Except that the rpm is higher when it is cold. Had the pan dropped. There was some metal in the pan, and the mechanic said he felt a slight shudder on the test drive. I don't know how much is too much metal in these. But it didn't seem excessive to me. I just bought the truck. I do not know if the fluid has ever been changed. Probably not. Truck shifts fine in all other situations. Seems to have lots of power and pulls through all gears. Is this a trans issue or an idle issue?
Thanks to all who answer.
Frank, I've merged your two threads on this subject. Please don't start duplicate threads on one topic because it can lead to confusing responses that waste everyone's time, including yours.
- Jack
- Jack
The IAC (Idle Air Control) is not part of the transmission. It is located on the engine throttle body.
Thanks Mark - I was wondering if a cleaning or replacement actually cured the symptom though as I would likely want to just replace it with a new one and move on:-)
I would at least try cleaning it first to see if it helps. If it doesn't help, then you need to start looking at other things. If it does help, then plan on replacing it sooner or later. It's very easy to get to.
Thanks Again!
ALR
