Auto Downshift problem
Old Jul 14, 2012 | 06:52 PM
BandBCamp's Avatar
Question Auto Downshift problem
I have an '02 Supercrew with AOD. When I slow down, either by braking or coasting, the truck goes down to about 400rpm's before downshifting. This happens with each gear change. 4th to 3rd, 3rd to 2nd, etc. If I push the button to turn the overdrive off, this doesn't happen, it shifts at 700rpm's. This problem is not intermittent, it happens every time I slow down while in overdrive. Does anyone have any ideas? I'm a little above moderately handy and can perform most maintenance tasks with some guidance. For this issue, I need some help. Thank You in advance.
Old Jul 15, 2012 | 10:29 AM
The AOD hasn't been used since the early/mid 90's - do you have a 4R70W or 4R100? Check the TRANS code on the door jamb sticker.
Old Jul 15, 2012 | 03:34 PM
BandBCamp's Avatar
The TR code on the sticker is the letter "U". I'm not sure what that tells me.
Old Jul 15, 2012 | 09:39 PM
Mark Kovalsky's Avatar
"U" means 4R70W.
To diagnose this you need a scan tool that can look at live data so that you can see what the computer is seeing, and what it is sending.
Old Jul 15, 2012 | 10:09 PM
BandBCamp's Avatar
Thanks Guys, I'll get this checked at a dealer tomorrow.
