Down shift vibration
Old Jan 18, 2012 | 07:41 AM
ATNryan's Avatar
Hi guys. Recently I have been having a issue with what I assume is my transmission. I drive a 2007 fx4 Screw with the 5.7.
When I am on the highway and go to pass someone or press down on the gas a little to hard, as soon as my transmission down shifts, I get a vibration like the gears are slipping, etc. Its almost like I drove on a rumble strip for a second.
It only happens on the highway from 4 to 3 (I think that's it). What do you guys think the problem is?
All help is appreciated. I searches a little on the forums, but was looking for something a little more specific.
Thank you in advance!
Old Jan 18, 2012 | 08:13 AM
Mark Kovalsky's Avatar
Old transmission fluid can cause this. It's probably the torque converter clutch shuddering. Replacing the fluid can often fix this.
Old Jan 25, 2012 | 03:15 PM
ATNryan's Avatar
As promised to another member for helping me with this issue, I wanted to share my fix with you guys.
The issue turned out to be that the #1 coil pack was going and misfiring. Replaced it and did all my plugs at the same time and everything seems good now.
I will follow up if there are anymore issues.
