05 FX4 transfer case filling with transmission fluid
There must be a seal between the transmission and transfer case that is leaking because I noticed my transmission level low with no external leaks, then today I was servicing my transfer case and notice it was WAY overfilled. I drained about 4-5 quarts out of it. I believe it should only have 2 qts. My question is how hard is it to pull the transfer case and can the trans. seal be replaced without removing the transmission?
