drain plug in TC?
Old Feb 28, 2011 | 02:37 PM
Jim Blackwood's Avatar
drain plug in TC?
2002 Lincoln Blackwood truck. Does it have a drain plug in the torque converter? Thanks
JB
Old Feb 28, 2011 | 04:22 PM
kingfish51's Avatar
Unlikely, the last year the F150 had one was 2001.
Old Feb 28, 2011 | 09:25 PM
Roadie's Avatar
My 2002 FX4 does not have one. My last truck a 2000 F1504x4 did have a drain plug.
Old Feb 28, 2011 | 10:51 PM
Mark Kovalsky's Avatar
The first two months of 2002 production had a drain plug in the torque converter. Most 2002s did not.
Old Mar 1, 2011 | 11:08 PM
OK, thanks. Guess I'll just have to take it to the jiffy lube.
JB
Old Mar 2, 2011 | 07:25 PM
Roadie's Avatar
That all depends. You can drop the pan every 20k miles or so and refill the pan. I'd install a drain plug and filter the first time and a new filter every 3rd time. In between, just drain from the plug and refill.
This is what I do.
Or you can use the procedure of disconnecting the cooler line and pump out a few qts, add a few until it runs clean. There is a procedure to do this posted somewhere on this site.
Old Mar 3, 2011 | 01:59 AM
Or you can simply take it to a place that has an exchange machine.
