c6 trans swap.
Old Jan 25, 2011 | 11:41 PM
  #31
b2therad's Avatar
How much $$ is that going to run me? I have a trans cooler as it it, but its tiny. I was just going to put a bigger unit on there.
Old Jan 25, 2011 | 11:57 PM
  #32
mxr181's Avatar
there is a couple threads on here, you can find the SD one for $100 online I think and its WAAAAAYYYYYY bigger than the stock one!
Old Jan 26, 2011 | 12:00 AM
  #33
str8t six's Avatar
http://www.partsgeek.com/gbproducts/...ek+Google+Base
Old Jan 26, 2011 | 12:01 AM
  #34
b2therad's Avatar
So what if I pick up a used one via the parts department at work? It would be super cheap. All I would have to do is straight swap it in right?
Old Jan 26, 2011 | 12:09 AM
  #35
mxr181's Avatar
check this out...
http://www.timskelton.com/lightning/...ds.htm#coolers
  #36
str8t six's Avatar
pretty much. here is a how to
http://www.svtperformance.com/forums...-intalled.html
and another
http://www.lightningrodder.com/forum...ghlight=cooler
how cheap could you get one?
Old Jan 26, 2011 | 12:21 AM
  #37
b2therad's Avatar
Thats alot of good info. I could get one pretty cheap I would assume. I would get a dealers discount.. so just like as though a dealer was purchasing the part.
Old Jan 26, 2011 | 12:27 AM
  #38
str8t six's Avatar
id buy one off ya if the price right.
Old Jan 26, 2011 | 12:33 AM
  #39
b2therad's Avatar
No problems.. I will check at work tomorrow. I am trying to not spend so much on the truck for a lil bit.. that trans set me back a bit
Old Jan 26, 2011 | 12:36 AM
  #40
str8t six's Avatar
yeah, transmissions are expensive!! i hope my stocker lasts a LONG time!
Old Jan 26, 2011 | 12:41 AM
  #41
b2therad's Avatar
.. and I still need to buy a engine.. Geezuz! My stock trans lasted 191k and then haha dump.
Old Jan 29, 2011 | 01:41 PM
  #42
b2therad's Avatar
Well its safe to say that I toasted my old trans. My dad helped me drop it out this morning, and the fluid is a nice brown color with the smell of burnt clutches. It was a little bit low on fluid(or so I am told), but it wasn't enough to have it run hot. Apparently it was just "its" time to go. Luckily we didn't have to take the exhaust out or even lift the truck at all to drop it either .
The new trans comes in monday so the truck is ready for it to go in.. just a waiting game now. I have a question. I am told that I need to get my ECU reflashed when the new trans is put in, and I have no idea where I should go to do that. Have any of you guys got yours reflashed and where did you do that?
Old Jan 30, 2011 | 04:30 PM
  #43
I don't know why you would need to get it reflashed if you are doing a straight swap.
Old Jan 30, 2011 | 08:56 PM
  #44
Mark Kovalsky's Avatar
A C6 won't bolt to a 4.6L. There may be an adapter available.
Old Jan 30, 2011 | 09:51 PM
  #45
b2therad's Avatar
Thats what I was thinking. The guy at monster said I should reflash it so that the computer doesnt think I still have the old trans in it. I appreciate the response. I probably wont get it reflashed.
SMH
