Seized Throwout Bearing
on
I had to remove the clutch pressure plate to get chunks of plastic out from in between the fingers. Put it back together with an old style slave with the blue bearing. The only problem is the slave is flimsy and the friction point is only an inch or so off the floor. Come summer the tranny is off again and an new style slave is going back on along with re-shimming the input shaft.
on
Luck of the draw for the bearing. Eventually you are bound to get one that is defective and I was the lucky one. The previous slave was installed a month before the blower and it lasted till last summer before it started to leak. The bearing was still good. Maybe I should have kept that old bearing instead. I think that you can no longer get the old slaves from Ford so I suspect that you would end up with a new model.
