Trans Problems '01 Screw
Old Jan 23, 2011 | 01:40 PM
iowabowhunter's Avatar
Hi
I have a 2001 F150 4x4 4.6 that Won't shift into 3rd or OD. No warning lights on the dash, and 1, 2 , and Reverse are fine. It has neutraled out on me once, but normally just stays in 2nd. Fluid looks and smells good, and there is no slippage in 1st , 2nd, or reverse. Truck has 96k. Am I looking at a full rebuild or is there maybe an easier solution??
Bob
Old Jan 23, 2011 | 07:37 PM
If it was the shift soleniod,,,,wouldn't it throw a code??
Old Jan 23, 2011 | 07:59 PM
phil6608's Avatar
You need a rebuild!
Same thing happened to me 2 times. ):
Phil
Old Jan 24, 2011 | 06:56 AM
Originally Posted by phil6608
You need a rebuild!
Phil
What was the problem??
Old Jan 24, 2011 | 09:00 AM
phil6608's Avatar
3rd and OD was wiped out!
Old Jan 24, 2011 | 09:33 AM
PickledPolak's Avatar
Likely you have a direct clutch problem. Very common. She'll have to come out and apart.
If you get it built, make sure you get the Alto direct clutch upgrade.
Cheers!
