97 4r70w replacement
Old Aug 17, 2020 | 10:00 PM
Kenny Jean's Avatar
F150 1996 1/2 ton cab swap to 2001 3/4 ton frame abs problem
Hey guyss i have a little problem here, im just finishing making the 1997 cab swap onto the 2001 frame, the abs and the speedometer dont work. Should i take the harness on the 1996 to put on the 2001?
Old Aug 17, 2020 | 11:04 PM
1996 and 2001 are not compatible, period.
Old Aug 18, 2020 | 06:15 AM
Kenny Jean's Avatar
everything fitted just fine just have that speedometer and abs problem the rest is A1
Old Oct 25, 2020 | 10:31 AM
Robert Riggs's Avatar
96 explorer 5.0 4r70w into 95 f150 5.0 4r70w?
Originally Posted by Darrin Burch
The harness repin info is out there on the internet. You might have to search a little, but it's there.
Can't use a 4.2 transmission because it has a different bellhousing pattern than the 4.6/5.4 pattern.
On those numbers, unfortunately there isn't any decoder out there to know what the differences are exactly. Usually though, if you choose a transmission from the exact same model truck you have then you are ok. If you swap for another one then you might have to change something. Again though, no guide exists for that.
Sorry I can only help in such a limited way.
Darrin
Will that work 96 explorer into 95 f150? Both are 5.0's
Darrin
Old Sep 29, 2021 | 02:02 PM
culpy14's Avatar
2000 4r70w into 2003
Hey,
will I have any issues putting a 2000 5.4L 4x4 4r70w transmission into a 2003 5.4L 4x4?
Old Sep 29, 2021 | 02:31 PM
Yes, there are differences. It may be as simple as a repin but cross reference shows that a 2003 needs a 2001-2003 transmission.
Old Jan 13, 2022 | 10:10 AM
f150lucas's Avatar
Great thread. I am hoping one of you has an answer for me. I have a 2000 F150 4.6 4x4 and the tranny just went out a few days ago. I want to replace it with a 2000 5.4 4x4 transmission and I found a few here https://reman-transmission.com/trans...es/?code=4R70W that are all remanufactured. Their sales staff has no clue if it will fit of course and I am waiting to hear back from their tech team. Do yall think it would be a direct bolt-on?
Old Jan 13, 2022 | 10:49 AM
A 5.4 4R70W same year and drive type is a direct swap on a 4.6.
Old Aug 23, 2023 | 09:52 AM
Yanmar83's Avatar
Will 1997 4r70w go in 2004 4r70w?
Both were 4x4 5.4L F150s except the 2004 was a heritage edition. The 1997 has white connector and the 2004 has a black connector.
Old Aug 23, 2023 | 10:31 AM
To put a 97 trans in a 04 Heritage it needs a repin.
https://www.f150online.com/forums/tr...ngability.html Post #34
EDIT: I wouldn't recommend it. See my reply to you in the other thread.
