95 e4od trans.? Help
I have a 1995 F150 5.0 E40D trans. 111,100. miles. Well it all started when I took out this fence & bent over a heavy duty post that dented my trans. pan on the driver side & caught the wireing harness. So I checked out the wires & found one with the insulation off but no other damage taped it up. Pulled the pan & found no damage, just left the dent (wasn't close to anything), cleaned it all up, tourqed it back down & filled it with fresh fluid. I had just changed filter 6'000 miles ago. Now my overdrive off light is flashing me what seems to be a four digit code 7333. Does anybody know what my truck is telling me? The wire I frayed probably grounded but don't know what it does. Wear the harness plugs in has no damage. Thanks,Bob
