Trailer Hauling
Old Sep 18, 2010 | 09:57 PM
TX_FX4's Avatar
Trailer Hauling
I have a few questions, I am thinking about buying a travel trailer and a little concerned about the transmission. I have a 07 FX4 do I have a cooled trans? I looked in the owners manual and I'm not sure of the wheel base on this model so is my limit 7600 or 7100 lbs? Also when towing a cargo trailer I know I have to turn the OD off I'm assuming its the same for a travel trailer. Any advice you have would be appreciated. Thanks ya'll. TEX
Old Sep 19, 2010 | 01:23 AM
FireEngineer's Avatar
Look in the front of your truck just behind the grille, if you see a smaller radiator infront of your main radiator then you have a transmission cooler
Old Sep 19, 2010 | 06:16 AM
Mark Kovalsky's Avatar
Every automatic transmission has a trans cooler. Period.
Old Sep 20, 2010 | 01:01 AM
TX_FX4's Avatar
What about the wight limit?
Old Sep 22, 2010 | 02:32 PM
The weight limit doesn't take payload into account. I'd recommend you do not get a trailer with a max gross weight over 7000 pounds. Leave the bigger ones for the 3/4 and 1 ton guys.
