Slipping with ratcheting sound
Hi,
Ford 1999 F250 XLT - 4.6L V8 FI (W) the upgraded 150, 2WD
Transmission is slipping or I hope torque converter or the lock. Slips on any acceleration any gear other then lightest peddle pressure on level ground. Seems to get better when warms up a bit. It makes what I can only describe as a ratcheting sound. Did drop the pan and filter change about 20k ago when I had a radiator cooling line leak. Fluid level is fine looks clean, etc. Wanted some sage advise or suggestions before I bring it to the shop. Thank you!
