Having Some Issues Need Some Professionals
Old Aug 26, 2010 | 02:34 PM
Chris Norton's Avatar
Ok this is my situation,
I have a 2000, F150 V6 XLT Supercab
I bought the truck with a magnaflow exhaust and the way they bent the tube caused my truck to vibrate hard.
So I cut off my exhaust and dumped it after the magnaflow 20-25,000 miles later.
I know that it vibrated the exhaust so much that it might have shook apart the catalytic converter a little because in cold weather start up there is a rattle and after 10-15 min it goes away. It sounds like its coming from there as well.
I haven't replaced the cat yet but I have a hard shift from 1-2 (after it warms up) and I took it to a trans place. I have an extended warranty and they had an adjuster come out. He told the trans guy that it was either a clogged cat or engine problem.
Does this sound right---
Would a clogged cat cause this problem and should I get it replaced.
If I replace it myself and I don't live in California but the car has California certified cat do I need a cali one.
And its not a bolt on cat would I just cut it off and slide the new one in and weld.
Sorry about all the questions but I'm stuck
Thanks for any response
Chris
Old Aug 27, 2010 | 06:27 AM
Mark Kovalsky's Avatar
A plugged catalyst can cause a hard shift. So can a broken 1-2 accumulator spring and a whole list of other things.
All catalysts are bolt on. You're just not looking far enough forward or rearward. When you buy a new one you will see that it bolts on.
Old Aug 27, 2010 | 02:02 PM
so about the catalytic converter do i have to buy a california one if i live in Nevada
Old Aug 27, 2010 | 03:53 PM
No, you can even save some money and get universal or high flow aftermarket cats. OEM cats are frightfully expensive.
