problem shifting into OD
Old Aug 8, 2010 | 12:10 PM
longhornfan's Avatar
Overdrive issues??? My transmission was rebuilt about 35,000 miles ago. Around 45 - 55 mph, its tries to go into overdrive but cant. It hits the gear over and over until I give it more gas. My ATF level is a little high. Would this cause this? Any remedies?
Old Aug 11, 2010 | 04:55 AM
Mark Kovalsky's Avatar
Too much fluid can cause a lot of problems. Get the level right and see if it's any better.
Old Aug 11, 2010 | 10:05 PM
I siphoned almost 2 quarts of ATF out and added some conditioner. The level is still a little high. I will probably be taking more out but I wanted the conditioner to not go to waste. The shifting problem is still present but not nearly as much and not as harsh. I think I will need to get a transmission flush and new filter. The ATF is pretty dark and slightly burnt smelling. I hope that fixes it completely. thanks
Old Sep 28, 2010 | 10:19 AM
G.Andrews's Avatar
Any update to the resolution of your problem?
