Tans light flashing
Old May 3, 2010 | 04:17 PM
Vigs07R's Avatar
Trans light flashing
The other day I had some minor slipping. Almost like a jumping. Didn't happen but once and then it went away.
My truck sat over the weekend without being driven. I was leaving for class and when I pulled out onto the main road the back of the truck was jumping really bad. I got up to 60 and it was fine and I looked down and the trans or differential light was flashing. So I turned back and got my sisters car....4 bangers suck.
Going to take it into work and have the dealer look at it. Hopefully it's nothing major.
Old May 3, 2010 | 04:19 PM
Vigs07R's Avatar
oops I meant trans light in the title. LOL
Old May 3, 2010 | 04:34 PM
sfam198's Avatar
how many miles? ever had the fluid changed? sounds like torque converter shudder. pretty common in the older 4r70w's from what i read when i had my old t-bird. the switch to mercon V was supposed to all but eliminate the problem from what i was told.
Old May 3, 2010 | 04:37 PM
Vigs07R's Avatar
just rolled 71 on it. As far as trans fluid I am not sure. Bought it used 4 months ago.
Old May 3, 2010 | 05:06 PM
sfam198's Avatar
depending on what the dealer says, you may just want to try changing the fluid.
Old May 3, 2010 | 11:05 PM
ahawk5082's Avatar
Had the same issue with my 03 Expedition at about 80k miles. Tranny would slip and the OD light was blinking. Turns out the tranny cooler was clogged. I installed a second tranny cooler about 2 years ago (cost about $40) and I have not had a problem since.
