what tranny do i have?
Old Apr 10, 2010 | 08:50 AM
2fast4u2's Avatar
how can you figure out exactly which tranny is in your truck???where is the tranny code?
Old Apr 10, 2010 | 09:05 AM
2fast4u2's Avatar
ok i figured it out i have the 4r70w.........can i use the E40D as a replacement in the truck without alot of screwing around will it just bolt right in?
Old Apr 10, 2010 | 09:42 AM
Veteran: Army
what's wrong with your current tranny???
Old Apr 12, 2010 | 03:26 PM
2fast4u2's Avatar
i have ONLY reverse....no forward gears at all......
Old Apr 24, 2010 | 10:02 AM
Mark Kovalsky's Avatar
To use the E4OD you'll need to change the computer, wiring, transmission mount, and driveshaft. Make that two driveshafts if it is a 4x4.
Old Apr 26, 2010 | 10:12 PM
ds450rider's Avatar
so how did u figure out which tranny u have??
Old Apr 27, 2010 | 01:29 AM
AZ Mr. Bill's Avatar
For 1997 to 2003, it should be in the trans code area of the build sticker. It will have either one of the following:
For the 4R70W you will see a "U" under trans code.
For the 4R100 you will see an "E" under trans code.
Old Apr 27, 2010 | 01:35 AM
Also, for the OP, the problem you are experiencing is either a worn or damaged forward clutch. It is either a hydraulic problem or a mechanical problem that requires a complete rebuild to fix. Sorry for the bad news.
Old Apr 27, 2010 | 09:49 AM
jbrew's Avatar
E = E4OD in your model (97-98), not 4R100. The 4R100 wasn't until 99. Same trans, -very little changes
