What ATF to use?
Old Mar 30, 2010 | 11:58 PM
skeeterboat's Avatar
Question What ATF to use?
Hello;
I own an 2006 SuperCrew 4x4 Lariat, it has 50,000 miles, I have to make the oil/fluid change of the transmission, but what ATF is better to use?: OEM Motorcraft Mercon V or Mobil1 Synthetic ATF (which meet the specification Mercon V), what do you recommend?
How often should be the ATF replaced?
Is it a good option the method of the Transmission Oil Exchange Machine?, which is mostly used on the fast-service lube stations.
I will appreciate your advises.
Best regards,
J.Leal.
Old Mar 31, 2010 | 12:04 AM
MGDfan's Avatar
Originally Posted by skeeterboat
Hello;
Best regards,
J.Leal.
Hello!
Either one is fine.
Some folks swear by Amsoil ATF: http://www.amsoil.com/storefront/atf.aspx
Good luck!
MGD v5.0
Old Mar 31, 2010 | 09:24 PM
UNITY's Avatar
And I prefer synthetic all of the time for both engine and tranny. Kind of depends on what you want to spend. like he said^ either should be fine. Most quick change stations (if any) will not use Synthetics. They cost to much.
Old Mar 31, 2010 | 10:07 PM
sam1947's Avatar
Most places I know will use whatever you want if you provide it. I replaced my tranny fluid with AMSOIL all I had to do was to supply the fluid, they will use it in their machine
Old Apr 1, 2010 | 12:17 AM
Thank you
Dear all, thank you very much for your comments, I will use the synthetic fluid.
Best regards,
J.Leal.
Old Apr 2, 2010 | 05:12 AM
Fifty150's Avatar
The best value is to stick with OEM Motorcraft Mercon V. Just like with Motorcraft Semi-Synthetic Motor Oil, you can afford to change it regularly & more often. For added protection & peace of mind, you can go with aftermarket synthetics. I've used several different types in my Ford transmissions over the years and have found good results with Lucas Oil, Red Line, & Royal Purple. Given a choice, I tend to favor the Red Line High Temp formula.
Old Apr 2, 2010 | 05:14 AM
Fifty150's Avatar
Old Apr 3, 2010 | 06:58 AM
openclasspro#11's Avatar
amsoil-over 200 k miles here on the stuff
Old May 8, 2010 | 09:24 AM
TNoff's Avatar
fluid help
Old May 8, 2010 | 11:28 AM
stephen muscio's Avatar
I use Motorcraft Mercon V.
Old May 12, 2010 | 10:44 PM
TNoff's Avatar
still can't decide...
Old May 13, 2010 | 05:48 AM
amsoil-over 1 million toublefree miles on my hvac company vans
Old May 17, 2010 | 04:57 AM
Fifty150's Avatar
What's your fluid change interval? How many miles between changes?
