Mercon III or V?
Old Mar 1, 2010 | 03:29 PM
NappyNick's Avatar
Mercon III or V?
Hey everybody, I've got what should be a simple question, but I can't find any answers and want to be sure. I've got a 1999 F-150 with 100000 miles and I want to change the trans filter and fluid. The code on my door jamb says "E" so its an E4OD. I have a Chilton repair manual that says use mercon III for an E4OD, and mercon V for a 4R70 transmission. I can't find mercon 3 and was wondering if it is now recommended to use V?
Thanks,
Nick
Old Mar 1, 2010 | 04:39 PM
Yep, Mercon V is now the spec for all E4OD/4R70/4R100 trannys.
Drain your torque converter too - it does have a plug.
Old Mar 1, 2010 | 05:51 PM
NappyNick's Avatar
Thanks man, better safe than sorry. Edit: I just saw you post answering another question similar to mine in another forum. On my dipstick it says just plain "MERCON." I'm confused and want what is best for my vehicle. If I only decide to drop the pan, change the filter, and top off, will mixing the mercon V and (what I assume is in it) III be bad? Or does it not matter because it meets the III specs?
Old Mar 1, 2010 | 06:54 PM
Roadie's Avatar
You should have a drain plug in your torque converter, so you should be able to get almost all of it out.
I previously had a 1995 Lincoln Mark VIII with the 4R70W. The Ford recommended fluid was Mercon. A former transmission engineer posted to all of us that we should switch to Mercon V. I switched as well as most of us on the Mark site and it worked fine.
Old Mar 1, 2010 | 07:40 PM
RayD's Avatar
You can use either Mercon or Mercon V. I don't think Ford makes Mercon any more so everything is back speced to Merc V.
There's no such thing as Mercon III, but regular Mercon and Dexron III were the same thing or at least compatible enough to be used interchangeably.
Old Mar 1, 2010 | 08:03 PM
NappyNick's Avatar
Alright mercon V it is. Thanks guys.
Old Mar 2, 2010 | 02:01 PM
If the fluid has never been changed, get it all out of there, don't mix it.
Plain "MERCON" does not exist any more unless you find some that's been in storage for years. Mercon V is better.
Old Mar 3, 2010 | 11:42 AM
NappyNick's Avatar
Yea, I was reading that I shouldn't mix it. I just got the truck at around 93,000 so I don't know whether or not it has been changed. I guess I got to drain it all.
Old Mar 3, 2010 | 12:12 PM
If you drop the pan and there's a plastic bobber in it, it's never been changed unless it was done with an exchange machine. If you drop the pan, put a new filter in.
Old Mar 3, 2010 | 09:42 PM
Mark Kovalsky's Avatar
No bobbers in the E4OD. The dipstick is different and uses a shipping cap, not a plug like the 4R70W.
Old Mar 8, 2010 | 10:41 AM
wacp2's Avatar
i will like to know how i can change the filter and liquid in my ford f 150 2003 fx4 ,i don't know what tranny i have.
Old Mar 8, 2010 | 11:01 AM
You most likely have a 4R70W. What is the trans code on the door jamb sticker?
Old Mar 8, 2010 | 11:13 AM
wacp2's Avatar
the trans code is in the door jamb or in the vin in what position
Old Mar 8, 2010 | 12:00 PM
NappyNick's Avatar
It is the letter underneath the letters "TR" on the door jamb sticker. Not in the VIN.
Old Mar 8, 2010 | 03:31 PM
Only the engine is in the VIN.
