2007 Harley Transmission question
I hate to ask a newb question, but what transmission is in the 2007 Harley truck? Also, what other years was this tranny offered? I might be looking to put one in a wreck that I bought. THanks in advance for the help.
its like a 4r75w or something like that i believe.
if it bolts up to a 5.4L what ever it is it will bolt right up to a 4.6L since the 4r100, and 4r70 trans' have the same bell housings(so i'm told), also there is on external difference between the 4r70 and 4r75, the only diff is on the inside.
o6yz250f-the rear end doesn't really matter he just may need to find a different drive shaft because of a difference in length.
Yes,
the 4r70,4r75 and the 4r100 will physically bolt up to the 4.6 or 5.4
Now if you go from the 4r70 or 75 to a 4r100 you run into a few more things that have to be changed. One being the computer.
The 4r100 is a lot bigger /longer so you need drive shaft adjustments,exhaust adjustments,different cross member,dip stick,dipstick tube,wire harness,computer and probably a few things I'm forgetting.
Phil
Phil
ya i know, i figured id tell him the main differences since he seemed interested.
