E4od
E4od
i have a 2000 f150 5.4 4x4 7700 with 87k and a E4OD auto tranny. i noticed that its leaking cant find from were(i think the little round black seal)is there a common leaky spot? anyway im going to change the fluid and was wondering what kind to use. it says mercon but im not sure. oh and one more thing, what color is mercon and mercon 5 supposed to originally be?
thanks
thanks
Actually a 2000 7700 will have a 4R100, not a E4OD - essentially the same tranny. There were 2 different ones used that year - so it will be either 17 or 18 quarts from dry fill. Just a pan drop will need 6.5 quarts. You should have a torque converter drain plug, and I recommend you drain it too.
thanks
