Ford F-150 Transmissions
I have a Chev Venture van right now that has a transmission that is on it's way out. I've looked at other vans but it seems like they are all prone to transmission failiure. So I decided to buy a truck now. I'm getting a 2003 Ford F-150 2WD extended cab for a 24 hour test drive tonight, it's got 75,000miles on it. I was wondering if this truck is also prone to tranny problems? I don't want to buy something else that will cost me $1500-$2000 to fix. It has the 5.4L engine in it and the truck looks really good other wise, now rust or dents anywhere. I had this style of truck along time ago for a company truck and really liked it, so I hope this will be okay.
Thanks for the reply. I really like the truck so I think I'm going to get it. In the meantime I called some of the guys are work that own these and they are very happy with them as well.
Ford automatic trannys are no different than any others - it could last you 300k or it could die tomorrow. There is no *history* of chronic problems if it's treated right and properly maintained, unlike some others. For peace of mind, if you buy it, I'd do a full fluid replacement, you don't know if it's ever been done before till you drop the pan or there are maintenance records.
That is what I was looking for, the Chevy Venture van has a long history of chronic tranny problems and that was what I wanted to avoid. The tranny shifts hard and fast in this one so I think it's good, fluid looks like new too. Did the 2003 5.4L trucks have a 4 or 5 speed tranny? I think it's a 4 speed but I read somewhere that some had 5 speed autos too?
my first 03 went 70k with zero problems, with a Jmod (shift kit) then the truck was totalled.
my second 03 screw has 76k with no problems so far, and ive put 2k on it since i bought it
there's a guy that just posted about his 1997 F150 with 360,000 miles with original motor and trans
I have a babied, and maintained '98 f150 with just over 100k. Trans needs a rebuild!!! My neighbours Ford diesel 4x4 with less miles than mine, fluid changed regularly is getting it's 2nd rebuild done as I type this.....$4000!!!!!!!!!!!!!!! They sure don't build 'em like they used to! My next truck will be a standard again!
don't ever confuse a guy with those words. it's a four speed. period. imagine telling a guy your five speed car is a four speed with od, or your six speed t56 is a four speed with two od's. you would sound like you belong in grade four. the 4 means four speeds the r means rear drive, the 70 is the torque rating, the w means wide ratio.
The 260 hp 5.4 in the 97 to 03 Ford F150's got the 4R70W. If you got the Lightning supercharged engine, you got the 4R100 which is a heavier duty transmission.
If you buy a 2004 and up 5.4 with 3valves/cyl. and 300 hp, you get the 4R100 transmission and the 4.6 engine gets the 4R70W.
The 2000 F150 Supercab 5.4 4x4 (with 4R70W)that I bought new had 105k miles on it when I sold it to a friend in Aug of 05. It now has 145k miles on it with no transmission or other problems.
I just bought a 2002 F150 Supercab Lariat FX4 with the 5.4 260hp engine and the 4R70W with 69k miles. I shall see how it holds up. Hope I don't sell this one below 250k miles.
Okay, I assumed it was a 4R100. I only knew the transmission was supposed to be a heavier duty trans than the 4R70W
What is the difference between the 4R100 and the 4R75E? Or is it a beefed up 4R70W?
According to the manual with my 2002 all 5.4 engines in 2002 got the 4R70W trans except for the Lightning which got the 4R100. It recommends Mercon V for the 4R70W and Mercon for the 4R100?
In 2002 MERCON was the specified fluid for the 4R100. In 2006 Ford changed MERCON V to be compatible with the 4R100 and dropped MERCON. MERCON V is now the right choice for both transmissions.
We could call it a one speed direct drive (1:1 ratio) transmission with two underdrives and one overdrive. That makes more sense than calling it a three speed with overdrive.
