Transmission fluid change
Just a quick question on the Tranny fluid change. I have a 2005 F150 STX. Changed the tranny fluid and filter the other day, and without thinking I added a few quarts too many. The level is definately above the max line. I am going to drain some out when I get a chance but I will have run the truck about a week before doing this. Just wondering will this hurt the transmission in any way? Any suggestions appreciated.
Yes, it can hurt the trans. Get the fluid out ASAP! If it's too high the rotating parts will whip the ATF into a foam. Foam can't lubricate, so metal parts will wear on metal. Foamed fluid is also GREATLY expanded, so you could have enough to force fluid out of the vent and/or dipstick. If that fluid lands on the hot exhaust, you might not have a truck any longer. Yes, I've seen that happen.
Well I put 7 quarts in so I think I only need to drain a quart or 2. When I dropped the pan I had just loosened the front bolts on the pan and probably about a quart drained out, but I will try the cooler line.
Or you can take it to a quick lube type place and have them suck it out. That is what I did, i overfilled mine by about a half quart or so and took it in and they sucked it out for free. I think if you drop the pan again and the gasket gets fluid all over it it could leak and keep leaking slowly......
This little device will do the trick.
Mityvac 7400 7.3 Liter Fluid Evacuator
Price: $52.36 & this item ships for FREE with Super Saver Shipping.
Product Features
* Evacuates all kinds of fluids including engine oil, transmission fluids, gear oil, coolant, and brake fluid
* Large 1.9 gallon reservoir (7.3 liters) hand operated pump for the big jobs
* Includes 5 feet of flex hose and two dipstick hoses
* Features polyethylene construction and will not rust or corrode for durability
* Quick-drain pour spout
Product Specifications
Product Information
Brand: Mityvac
Sizing and Specifications
Item Weight: 7.4 Pounds
Product Description
Product Description
Mityvac 7.3 liter fluid evacuator features stiffening ribs for added durability. The redesigned pump handle is stronger for heavy use and longer tool life. A larger base prevents the chance of tipping and spills in shop.
Product Description
Larger Capacity Fluid Evacuator The recently introduced Mityvac 07400 Fluid Evacuator is ideal for use in the shop or at home. The 07400 removes all types of fluid in a range of applications from cars, trucks, boats, RVs, ATVs and small engines. The easy-to-use 07400 Fluid Evacuator provides a larger, more durable reservoir than its predecessor the 07200, increasing the fluid capacity to 1.9 gallons (7.3 liters). Its larger base and redesigned foot stabilizer increase steadiness, reducing the chance for spills.The 07400`s durable pump handle has been strengthened to resist fracture and increase product life. Its unit handle has been redesigned with a longer, more comfortable grip, and the pressure relief valve has been relocated for operator convenience.The unit`s polyethylene construction is easy to clean and resists automotive and household chemicals. Requiring no electricity or compressed air to operate its manual pump, the 07400 is light and portable, and its built-in automatic shutoff prevents accidental overfill.APPLICATIONS: Drain engine oil or transmission fluid directly through the dipstick tube. Drain coolants from radiators, and brake and power steering fluids from reservoirs. Use with Mityvac Brake Bleeding Accessory Kit P/N 07205 to bleed brakes lines. Works great on cars, trucks, motorcycles, RVs, ATVs, lawn and garden equipment, boats, and much, much more. FEATURES: Automatic shutoff prevents overfill. Durable polyethylene construction will not rust or corrode. No electricity or compressed air required. Large capacity 1.9 gallon (7.3 liter) reservoir. Convenient pour spout allows quick draining. Includes a 5` (1.5 m) long flexible main hose and two dipstick hoses for motor oil and transmission fluid evacuation. Convenient foot bar for increased stability. INCLUDES: 1.9 gallon (7.3 liter) Reservoir w/ Hand Pump 0.41" (10 mm) OD x 5` (1.5 m) Long Evacuation Tube 0.26" (6.5 mm) OD x 5` (1.5 m) Long Dipstick Tube 0.22" (5.6 mm) OD x 5` (1.5 m) Long
Product Features
Product Information
Brand: Mityvac
Product Description
Product Description
Product Description
