what tranmission do i have
Old Feb 23, 2009 | 04:52 PM
griff 73's Avatar
hi guys
i have a 97 4.6 v8. i am wondering what trans i have? are there other trans units that bolt up? i worked on vw for a while and there parts interchange all over the place. i hope ford does the same. thanks dave
Old Feb 23, 2009 | 06:36 PM
projectSHO89's Avatar
Read the TR code on the door label.
You have either a 4R70W (most likely) or an E4OD.
Old Feb 23, 2009 | 07:16 PM
griff 73's Avatar
thanks.. im looking to get the best mpg i can and still pull the trailer when i have to. will any other trans bolt up?
Old Feb 23, 2009 | 08:17 PM
yetti96's Avatar
So you are wanting to swap trannys to get better MPG?
Old Feb 23, 2009 | 08:28 PM
griff 73's Avatar
yes.
in the vw world tdi trans will give a good all around power band but more so good mpg
Old Feb 23, 2009 | 10:16 PM
Mark Kovalsky's Avatar
All 4.6L trucks have the 4R70W.
There is no transmission that will give you better fuel economy.
Old Feb 24, 2009 | 07:49 AM
griff 73's Avatar
thanks. just wanted to check.
Old Feb 25, 2009 | 01:31 PM
griff 73's Avatar
so the 4r70w trans is the same in all applications? i did some looking and found out it was used in the stang gt, ltd and a few other models. my question is do they all bolt up the same and are the sensors the same? i think i read that ford started using them in 1980-like 2003.
Old Feb 25, 2009 | 06:57 PM
jtarms45's Avatar
I've got an '08 5.4L, 4X4, Lariat SCrew. What tranny do I have in this thing?
4R70E or a 4R75E, or a 4R100?
Old Feb 25, 2009 | 07:23 PM
mikerosi's Avatar
What`s your trans code??
Old Feb 25, 2009 | 07:54 PM
jtarms45's Avatar
No idea where that is...? I thought it was on the drivers door.
Old Feb 25, 2009 | 07:55 PM
It's a 4R75E. The 4R70E is used with the 4.6L, the 4R100 went out of production at the end of 2004.
