Shift Kit Questions
Old Nov 8, 2008 | 12:42 PM
If you are maxed out, I'd leave the OD off permanently.
Old Nov 8, 2008 | 11:39 PM
twintips_17's Avatar
I thought that the reason you leave it off is to prevent it from shifting back and forth. There for creating heat and limiting the life of the transmission. If you keep the torque converter locked and prevent it from shifting by not useing the cruise control and watching the load meter to keep it from shifting. Wouldn't that be ok?
Old Nov 9, 2008 | 01:38 AM
You will be closer to the power peak by running in 3rd with the converter locked. It's easier on the whole drivetrain. If you had 4.10's or better in there, it might be a different story.
Old Nov 9, 2008 | 04:26 AM
Klitch's Avatar
i learned something from darrin burch on these 4r70w's... OD band is too easy to ruin, if your hauling heavy, turn od off.
Old Nov 9, 2008 | 09:10 AM
You convinced me. I just hate running at 2500 when i could be at 2000 rpm's. But if it will make the transmission run longer then im in. Has anyone heard of a zf5 or 6 swap. I really hate having an auto.
Old Nov 9, 2008 | 10:49 AM
How fast are you driving pulling that bigass load?
Old Nov 11, 2008 | 12:04 PM
I was driving 75 on the flats. I went over a scale and the truck and trailer loaded weighed 11,180. How much do the supercrew weigh empty? I stopped towing with over drive on. The truck would hold it in overdrive without unlocking the torque converter through all the small rolling hiles and flats. But on the side of caution i stopped.
Klitch....
What did you decide to do with your transmission?
Old Nov 11, 2008 | 01:33 PM
Don't flame me, but you shouldn't be towing that fast. You should keep it down to 65.
Old Nov 11, 2008 | 11:32 PM
Klitch's Avatar
waiting on dispute to close... draggin his feet...
also, the thing i hate about people preachin the od off idea with towing is that means i have to either do 55mph on speedo (50mph roughly) so i dont burn so much fuel i cry. or i have to travel at 70mph (65 roughly?) and burn around 9mpg... or less...
Old Nov 12, 2008 | 08:02 AM
Darrin Burch's Avatar
Let me know when things are taken care of on your end.
Darrin
Old Nov 12, 2008 | 09:19 AM
Klitch's Avatar
I will Darrin, i been trying to keep Mike T in the loop too so i can send him datalogs without him giving me guff. im strongly considering just ordering it soon so i have something to do on christmas.
Old Nov 12, 2008 | 09:41 PM
People are starting to think I work for Troyer. LOL
I don't. I am in Indiana and Troyer is in Virginia. It is logistically impossible.
I steer people to him for several reasons. The most important being that he knows more about these trucks when it comes to performance than anyone else I know and he sells only the best products.
Darrin
Old Nov 12, 2008 | 11:36 PM
Klitch's Avatar
lol i've never tried to imply that.
Troyer pointed me to you at one point because he felt you'd handle my needs the best to his knowledge.
