6 speed Tranny
Old Oct 15, 2008 | 10:53 PM
Typow07's Avatar
6 speed Tranny
SO, i havent taken my gov off and i get to 95 mph in 4th gear at 2500rpm, thats no where nearall the power i got, i think if i took the gov off i could get atleast 120, but how hard would it be to atleast drop in a 5 speed transmission, or even a 6 speed?
Old Oct 15, 2008 | 11:14 PM
Drop one into what?
Old Oct 15, 2008 | 11:29 PM
Paralyzer's Avatar
kids....
Old Oct 15, 2008 | 11:36 PM
bigredtruck06fx's Avatar
someones had more bers than me
Old Oct 16, 2008 | 10:40 AM
Typow07's Avatar
haha w.e ill do it my self then!! haha
Old Oct 16, 2008 | 12:07 PM
If you are talking about an automatic in that truck, no, you can't easily put a 5 or 6 speed automatic in, and it won't do anything for you anyway except give you a bit more pull off the line because 1st gear is lower. Top gear is pretty much the same ratio in all 3 transmissions.
Old Oct 16, 2008 | 02:11 PM
MitchF150's Avatar
Like glc said... No matter how many 'speeds' a tranny has, it's top gear is still only going to be around a 0.7:1 ratio... Maybe 0.6, but it'll start to bog the engine down at that point, just going thru the air at over 120mph...
Even if you only had a 2 speed trans, if it's top gear ratio is .7:1, then you'll still only get to that same top speed figure (sans speed limiting governor) as the engine is capable to go...
It's not like if I had a 100 speed bicycle, I can go any faster then I could in top gear then on a 10 speed bicycle....
Mitch
Old Oct 16, 2008 | 04:02 PM
Arca_ex's Avatar
I see in your sig it says you have a power adder intake eh. Do you even know what a power adder is? You blown? Turbo'd? Runnin' the bottle? If so then you would already have a tune now wouldn't you.
And if it's the company name then they really need to think of something else...
Old Oct 16, 2008 | 10:46 PM
Typow07's Avatar
ooo i see, well the box says spectre performance and the filter itself says power adder.... happy? its the same as any k&N intake its a polished tube with a big red filter on it
Old Oct 17, 2008 | 12:34 AM
Arca_ex's Avatar
Well assuming it doesn't say K&N then well... it's not the same as any old K&N.
Old Oct 17, 2008 | 12:19 PM
adrianspeeder's Avatar
Your gov is there for a reason. What speed rating is on your tires?
Tranny swap would be an actual project taking lots of planning, fab, time and money.
Adrianspeeder
