Odd situation with Cruise control
Old Jun 18, 2008 | 01:21 PM
allenm100's Avatar
what?
with a truck like that you cant find the master cyclinder?lol
Old Jun 18, 2008 | 06:51 PM
Paralyzer's Avatar
the brake pressure switch is only there as a back up incase the brake pedal switch fails. its does not turn off the cruise normally.
Old Jun 18, 2008 | 11:34 PM
jbrew's Avatar
Yea , WOW
Old Jun 18, 2008 | 11:36 PM
jbrew's Avatar
[QUOTE=Jditta;3250015]Im not screwing around, I dodnt know where the master cylinder is located. QUOTE]
Well , if your serious.
You could use ^ ~ One of those..
__________________________________________________ _____
Cruise Self Destruct Switch -
It's that "Red" deal~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^~~~~ Up there..
__________________________________________________ ______
Master Cylinder -
On the Right~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^~ Here.
__________________________________________________ ________
Ahaaaa, found a good one for yuh -
Old Jun 19, 2008 | 01:01 AM
Klitch's Avatar
allen: most people buy it done.
i'll be frank, these guys probably have u going in the right direction. those books are at napa/schucks/autozone/motion auto/any parts store basically. get one, great for troubleshooting little things like this sometimes.
check out the switch. it could simply just be dirty, but that requires patience and tearing it all apart. (something i do to save cash)
i on the other hand have different odd issue with cruise ive never heard of... the SOB surges going down hill. like it cant figure out where to place the throttle.
Old Jun 19, 2008 | 06:00 PM
Jditta's Avatar
Thanks for the help guys, and yea I know I'm stupid I don't know much about this kinda stuff.
Old Jun 19, 2008 | 06:40 PM
jbrew's Avatar
You can get schooled here
Any questions ? Try the search bar - great feature.
Old Sep 5, 2010 | 09:01 PM
zamp's Avatar
Hi Jbrew my cruise stopped working today. the cruise lite flashes the immediately goes off. i tried the diagnostic procedure all went well. the pressure switch on the master cylinder was soaked with brake fluid and i have had the recall done. how do you change this switch. thanks
Old Sep 5, 2010 | 09:59 PM
Go to the dealer, spend $26 for a new improved disconnect switch, unplug the electrical connector from the leaking one, unscrew it, screw the new one in, and reconnect it. Top off the brake fluid.
Until you can get to the dealer, disconnect it!
Old Sep 6, 2010 | 04:27 PM
zamp's Avatar
Thank you went to napa this morning. Old swich had no continuity, new one did.cruise now works thanks
