best spot to drill?
Old May 12, 2008 | 02:40 AM
warrick717's Avatar
best spot to drill?
i have an autometer trans temp guage i just bought. runnin 38's so i wanna keep an eye on it. its an electrical guage, and the tranny is an E4OD with shift pack. the instructions suggest to drill and tap the pan but i dont want it sticking down like that. if antone knows FOR SURE if i can drill and tap anywhere else thats not sticking out i would really appreciate it.
thanks
joe
Old May 12, 2008 | 08:36 AM
Mark Kovalsky's Avatar
There's a port on the driver's side of the trans, just above the pan, towards the front of the trans. It has a black hex head pipe plug in it. That's where I recommend placing the sender. It's already tapped for 1/8" NPT, which is what most of the senders are. I've measured temperatures there and in the pan at the same time and only see a couple degrees difference, sometimes higher, sometimes lower.
Old May 12, 2008 | 09:34 AM
Galaxy's Avatar
You can't just drill and tap a pan anyways...waaaay to thin. The only way to install in the pan is to drill a large hole and have a threaded bung welded in.
Old May 12, 2008 | 10:55 AM
successtrainer's Avatar
[QUOTE=Galaxy;3203446]You can't just drill and tap a pan anyways...waaaay to thin. The only way to install in the pan is to drill a large hole and have a threaded bung welded in.[/QUOTE
I drilled my pan and used nylon washers, rtv and haven't had a single leak. I agree, welding it in is the best way, not the only way though.
Old May 12, 2008 | 05:17 PM
warrick717's Avatar
thanx
i will give it a shot this weekend. i already have the wires ran and guages hooked up, just have to put the unit in and connect the wire.
by the way what should my average temp be?
again i have 38 x 15.5 mickey t's and 4.56 rear if that matters
Old May 12, 2008 | 09:24 PM
Galaxy's Avatar
Nice...I'd never do it, but cool.
Old May 12, 2008 | 10:29 PM
fx4_613's Avatar
im doin a gauge install like this soon too thanks for all the info guys i think im gonna try the the plugged hole mark mentioned
