What should I do???
Old Feb 6, 2008 | 05:25 PM
01Screw17's Avatar
yeah im really tring to avoid a flush b/c i have heard of so many trannys going out after having it done.
Old Feb 7, 2008 | 08:55 AM
Mark Kovalsky's Avatar
Don't drop the valve body. You will get yourself in over your head unless you are experienced inside an automatic transmission.
If you only drain the pan you'll need 5 to 7 quarts. If you drain the torque converter, too, you'll need 12 to 14 quarts.
Old Feb 8, 2008 | 06:24 PM
Originally Posted by Mark Kovalsky
That won't get the fluid out of the torque converter. Half of the total fluid is in the torque converter.
If you pull the valve body it drains the top half of the convertor. My 03 didnt have a plug on the convertor, so pulling the valve body was the best i could do. I pulled out 10-11q and put in 11q. I think that is a pretty complete drain and fill on a 3gal (12q) system
That's a bad comparison. An engine is designed to drain all of the fluid by removing the drain plug and the filter. A trans isn't like that.
I know not all comparisons can be perfect, but hopefully he caught my drift
