replacing a 5.4L with a 4.6L
Old Jan 31, 2008 | 08:15 PM
LoCo F150's Avatar
Question replacing a 5.4L with a 4.6L
I have a friend that bought a work truck that had a bad 5.4L in it. He has looked everywhere for a decent price on a 5.4L but has had no luck. He can get a really good deal on a 4.6L but doesn't know if the tranny from the 5.4L will bolt directly to the 4.6L. I think its an auto, so I'm assuming he will need to switch out the computer. Is there anything else we need to look at?
Old Feb 1, 2008 | 08:56 AM
Mark Kovalsky's Avatar
The trans will bolt up. There could be a problem with making it work right, however.
The 5.4L came with either the 4R100 or the 4R70W. The 4.6L only came with a 4R70W. If he keeps the original computer it will run the trans fine, but I don't know about the engine. If he gets a new computer for the 5.4L make sure that it is one that is for a 4R70W. If so, everything should work fine.
Old Feb 1, 2008 | 09:08 AM
crash_lucky13's Avatar
if you're anywhere near abq i have a 5.4
Old Feb 1, 2008 | 10:23 AM
JMC's Avatar
JMC
25 Year Member
In the long run your friend would be better off paying a little extra to find a 5.4.
The bolt pattern for both engines are identical. If he still opts for the 4.6 make sure that you use a torque converter from a 4.6. It has a higher stall speed and that will allow the little 4.6 to huff a little longer to build up its power.
JMC
Old Feb 2, 2008 | 09:57 PM
00F150power5.4's Avatar
it would bolt up..but man he wont be happy with going from a 5.4 to a 4.6..haha...you just cant down grade...haha the 4.6 will end up working a lot harder....just not worth saving a buck
Old Feb 2, 2008 | 10:39 PM
JMC's Avatar
JMC
25 Year Member
So how is this project going?
JMC
Old Feb 3, 2008 | 10:38 AM
dirtyd0g's Avatar
I'd use the 4.6, just add boost Some 5.4's had the high stall converter, others had the low stall. I find usually the vans and heavier trucks have the high stall. Completely the opposite of the way I like to see it done, but hey thats ford for you. IMO more weight use less stall. Lighter vehicle throw some stall at it. Weight is more of a factor than anything to me. You'd probably have to drive them all different ways to see the difference.
Alan
