99 F150 5.4L Red Line?
Old Nov 15, 2007 | 08:33 PM
broox's Avatar
So I noticed something the other day... My Tachometer doesn't have a red line on it, wtf?
Can I really safely bury my RPMs? Where should the red line be?
Old Nov 15, 2007 | 09:02 PM
I would not rev it over 5200 or so - the torque converter can't handle it.
Old Nov 16, 2007 | 05:48 AM
LastSplash's Avatar
The PCM has a rev limiter programmed in it so you are not supposed to be able to over rev the engine.
Old Nov 16, 2007 | 10:41 AM
broox's Avatar
ah, so i could just drive it hard and the truck will decide where to stop?
not that i plan on beating my truck to death... i just don't want to accidentally overstep my boundaries.
the RPMs go up to 6000, so i sort of just decided that 5000 was the redline.
Old Nov 16, 2007 | 11:35 AM
Mark Kovalsky's Avatar
The torque converter can take any RPM that the engine can run. There is a rev limiter that will keep the engine (power on) from exceeding the speed that anything connected to it can run.
Old Nov 16, 2007 | 12:57 PM
Just leave it in Drive - it will take care of itself.
Old Nov 16, 2007 | 01:56 PM
malexander52's Avatar
5400 Rpm
Ford does not recommend spinning the factory torque over 5400 RPM due to ballooning.
Old Nov 17, 2007 | 09:29 AM
That's true, and the fatory rev limiter is going to keep the engine from spinning over 5400 RPM.
Old Nov 17, 2007 | 01:26 PM
Neal's Avatar
Cool
HI!... The factory converter is junk. It fails quickly if revving over 6000RPM. I ballooned 4 of them in 4 years. Now I run a P.I converter and have no issues.
Old Nov 25, 2007 | 08:01 PM
ssj4shane's Avatar
what happens when you ballon a converter
Old Nov 26, 2007 | 05:07 AM
phil6608's Avatar
You now have an expensive paperweight,,,lol.
Phil
Old Nov 26, 2007 | 02:31 PM
ssj4shane's Avatar
thats a funny one lol
But if you ballon one do you spill trany fluid and stuff ?
because my tranny is makeing alot of noise and in first gear the truck wants
to come to a stop...I have to give it gas to move like 1/3 of the pedal... I
was woundering if thats what could have happen..
Plus my tranny spit fluid out... and how can it spit fluid out if im not overfilled..
my gaskets on my t-case look ok...
what would make the fluid come out...
Old Nov 26, 2007 | 05:07 PM
MmmBuckles's Avatar
yep. most likely the torque converter. especially since 1st doesnt go anywhere without giving it gas
Old Nov 26, 2007 | 06:30 PM
ssj4shane's Avatar
if i put it in drive the truck can move some... havent tryed to go no were
besides like 4 feet
but i cant back up at all
