98 4rw70w problems... i bet its shot
Old Nov 25, 2007 | 03:09 AM
ssj4shane's Avatar
4r70w
my truck started makeing a noise about a week ago... like a cat rattle noise
so i was thinking it was my catsss sence i have high flows
butttttt on the way home today
it was messing up real bad... 1st gear
if i put it in first gear the truck comes to a stop and i have to give it gas
to go... like in first the truck wants to stop
2ed seems ok i think
3ed makes noise.. alot of noise
4th/od seems ok....
from the sounds of it you think its dead ?
Old Nov 25, 2007 | 04:48 AM
shifty_85's Avatar
check the fluid lvl? also smell the dipstick for burning/discolor. or something in frist is gone.
Old Nov 25, 2007 | 02:09 PM
ssj4shane's Avatar
well i havent moved the truck sence this morning
i bet its low on fluid so ima buy some in a little and hope i can just
drive it for a little.... Im goin to price out a MonsterBox and see what
prices i can get for a rebuild...
if its blown... Im going blown/turbo or superchager after this because then i can
just really dident want to spend money
but then again the worst thing i hated about my truck was how it shifts..
i hate sloppy shiftying
O ya the thing i feel about the fluid is something broke... Because there is fluid all over the transmission.. but not on the trans pan
Old Nov 25, 2007 | 07:56 PM
ssj4shane's Avatar
Ok how can fluid get out of a transmission
my cooling lines seem fine...
pan is dry..
but alot of oil around the whole tranny..
there is oil above the tranny on the cab floor..
Old Nov 25, 2007 | 08:31 PM
Mark Kovalsky's Avatar
If it's overfilled it is going to come out of the vent cap, which is on top of the trans.
Old Nov 26, 2007 | 02:04 AM
ssj4shane's Avatar
i know its not overfilled...
i have not added fluid in months....
for some reson it desided to spit it out
did you not read the post that you responded to befor ?
Old Nov 26, 2007 | 09:30 PM
Ben99R1's Avatar
ssj4shane. I changed a polyurathan(SP) gasket that goes into the trans. front drive shaft gasket. On my truck it would only leak when I was driving on the mountains. But it did leak trans oil on the tranny. You mite want to check it out. Good luck Ben
Old Nov 26, 2007 | 11:41 PM
ssj4shane's Avatar
i put some fluid in it today...
i cant back up at all...
the truck will go forward but i dont want to drive it untell i need to get
it to were ever im going to pull the trany...
i dont have a area to work so i have to go to a buddys or something...
Any one ever do into on swapping in a 5 or 6 speed ?
Old Nov 27, 2007 | 01:42 PM
CRASH594's Avatar
I just had issues with mine for the price of a filter and fluid its worth a try to change. You have nothing to loose
