4R70W Transgo Shift Kit Install
Old Apr 13, 2008 | 02:30 AM
  #31
Delirium's Avatar
Lol, well I figured that's what it did, but I didn't know what it was called and whether or not the fluid was ATF that circulated with the Transmission fluid. What's it take gear oil like the differential?
Old Apr 13, 2008 | 02:31 PM
  #32
Klitch's Avatar
well if your unlucky like me, it does share atf with the trans. my seals arent any good so the trans seems to slowly fill the transfercase.
Old Apr 13, 2008 | 02:33 PM
  #33
jbrew's Avatar
That would suck - Prolly end up spewing out the tailshaft seal
Quit laughing
Old Apr 13, 2008 | 02:41 PM
  #34
Klitch's Avatar
priorities! i figure its an easy fix when i have the time. til then, just an excuse for fresh fluid!
Old Apr 13, 2008 | 03:59 PM
  #35
Delirium's Avatar
lol, I'm putting amsoil ATF in my tranny like Jbrew suggested. What would you reccomend for the front and rear differentials and for the transfer case?
Old Apr 13, 2008 | 04:15 PM
  #36
jbrew's Avatar
I went w/Amsoil on everything in drive train (even Amsoil TEFLON grease slicked on the spline shaft) - No vibration @ 65MPH in 4WD on the E-way - The rear end is Amsoiled - The front Piig is Royal Purple (couldn't get Amsoil for that at the time). Amsoil in the Trans /Tcase (2 quarts) and Power steering (not one noise in the PS in two years)
Hope the bank account is stocked up
You DO get what you pay for here and it can save your a$$ in repairs down the road. My trans was very hurt before adding this kit and Amsoil 2 years ago. Runs and drives like new still - Doesn't slipp and hits every gear without a pause or hanging.
Old Apr 13, 2008 | 04:42 PM
  #37
Klitch's Avatar
well i was in my rear diff so often i just started putting napa off brand 80-90 in there since it was only there for a few months at a time.
Old Apr 13, 2008 | 05:52 PM
  #38
jbrew's Avatar
That's considered and illegal operation that will compromise a good rear end.
You might as well use maple syrup - because that oil doesn't even make the grade. That's way out ..
Old Apr 13, 2008 | 05:56 PM
  #39
Klitch's Avatar
how so? i dont have anything stock back there anymore. no LS, all new bearings, yes i check them and their cups and theyre perfect shape.
Old Apr 13, 2008 | 06:09 PM
  #40
jbrew's Avatar
O - Then I stand corrected - I don't know what the hell goes in there now - It's not factory, it's an after market install, so it's whatever the manufacturer suggests for the third member in your situation.
Old Apr 14, 2008 | 12:23 AM
  #41
Fifty150's Avatar
Where, on the map, is JerkWater? I've been driving around in circles all night.
Old Apr 14, 2008 | 01:05 AM
  #42
Klitch's Avatar
LOL wtf is with your comments tonight fifty?
anyway yeah jbrew, i thought you kinda had a notion with all my problems with my rear end it werent stock anymore :P
as far as what the 3rd party mfg recommends, they dont say anything specific.
Old Apr 14, 2008 | 11:36 AM
  #43
jbrew's Avatar
I wonder if that's why you had so much trouble with them in the past.
What oil you using "Wolfs Head"
Old Apr 14, 2008 | 11:58 AM
  #44
I personally have done a Jmod on my truck (2003), and just did a jmod on a 2005 5.4 4R75E , the newer trans have electronic shifting even though its the same internals. It is noticeble but not that noticeble of a difference.
Ill make a video of it soon
Old Apr 16, 2008 | 01:00 AM
  #45
Klitch's Avatar
i convinced myself the reason i had problems was a ****ty locker inside my open carrier that vibrated the ring gear bolts out, causing damage to the threads on their way out. so even though i replaced the bolts, the ring gear itself was worthless. in turn the pinion was probably fractured from the impacts of trying to shear those bolts.
again, all speculation.
