Rear tranny seal
Rear tranny seal
Hey fellas my rear tranny seal popped out of the tranny and I replaced it and it happened again the same day.I currently have a 7.5" lift and 110,000 mile on it.Also my leaf springs were loose for about two weeks until I tightened the springs the same day I replaced the seal.My question is may it be possible that all these factors may have done serious damage to my tranny because the tranny drives fine but the seal keeps popping off and fluid come out.thanks
I guess I should ask first, did it start when you added your lift? Your driveline angle is going to be pretty severe. Make sure your u-joints are good. Remove your driveshaft and wiggle each joint in both directions. If there is any binding, replace it. Also, is the truck 4x4, one piece or two piece shaft?
Ive had the lift on since sep of 06 and no problems.My truck is a 2wd and has a one piece driveshaft.The problem happened in the last week.On my way from work the seal popped off I replaced it a few hours later I jumped on the freeway and 2 miles down the road it popped off and Im stumped.Thanks for the info
