How bad is the 4r70w?
I am looking a a 2001 SC F150 4X4 with 80k on it and wondering how you guys feel about this tranny? I know Ford doesn't make real good trannies and just wondering what I need to look for.
Also if I do get it besides a big tranny cooler what else can I do? The truck is on 35s, but will get regeared to 4.56s asap.
Not bad at all! It is a great tranny as long as you maintain it properly.
Do a shift modification on it, and it really wakes it up!
DO NOT USE TRANS-GO SHIFT KITS. Go to TCCOA.com, and read the tech articles in the transmission section there for information on what to do.
Alan
Originally Posted by dirtyd0g
Do not J-mod a truck valvebody in order to do those mods you need a car valvebody. I suggest the FactoryTech seperator plate kit as it was designed to be used on thruck valvebodies.
Alan
Alan
Originally Posted by casey_1
No. If you want the trans cooler, get a better cooler. A pan doesn't help cooling much.
I put in one of these...
http://www.troyerperformance.com/cgi...gno=PPI-ATCKIT
Granted I'm pulling a 6500# trailer in FL heat. I installed it before the Factory Aux tranny cooler. I also put in a tranny temp guage which I would recommend doing first if you're concerned about heat. You may not need a bigger/extra cooler if you're not going over 180-190 degrees-F. If you plan on doing hard offroading or towing then you may very well want the extra cooling.
edit: oh, 2002 5.4 3.55ls 4x2
people will bolt everything on in an effort to increase performance but sometimes may forget to keep recycling hte fluid
change the fluid completely every 15-20k miles (10-15 if you tow hardcore). if you have a stock transmission cooler, it is usually more than adequate unless you tow large loads, even with tires and gears. a simpler way out for additional cooling capacity is adding a small e-fan to your stock cooler. plumbing for a larger cooler will leak if not done properly and is a hassle compared to crimping a few wires
my buddy put a gauge to his 2002 fx4 with 35's , tow package, and stock 3.73s, he stayed in a reasonable transmission temperature range the whole time, only coming barely into the yellow at a dead stop in 100 degree heat
Originally Posted by hmustang
Mine lasted 96k before acting up then I traded it in for my current truck.
Just recently the overdrive started acting up. I figure with that many miles it has a right to act up. So soon I'll be putting the old Engine and Trany out to pasture. Time to install some fresh horses under the hood.
Doug
Alan
Alan
I did that on my truck, and it works like gangbusters.
