cruise control???
Old Jun 20, 2006 | 05:18 AM
countryway20's Avatar
Exclamation cruise control???
well just had my clutch put in my 2001 ford f-150 5 speed, 4.2L v6, last week, and saturday i ment on a trip in my truck wwell short story went 6 hour long trip with no CC working? did they might have not plug something back in when changing out clutch???? i would take it back to them but there on south side of houston and i dont have time, just thought anymoe should know why it dont work, it worked before i sent the truck to them.
Old Jun 20, 2006 | 12:01 PM
chester8420's Avatar
Check and see if they hooked it back up onto your engine. Mine has a little clip that holds a rod onto the throttle body. They might have missed it when putting your engine back in. Also, make sure that the plug(s) are plugged in correctly into your master cylinder. I don't think the cruise control will work without the plugs plugged in, cause they tell the cruise when the brake petal is depressed, but I may be wrong. You might want to check some fuses too....
Old Jun 20, 2006 | 02:11 PM
JMC's Avatar
JMC
25 Year Member
To replace the clutch doesn't require removing the engine. In their haste to complete the job they may have neglected to plug in the output shaft speed sensor. It should be on the side of the extension housing on the tranny. Other than that they may have disconnected the deactivation switch that is located on the brake master cylinder. Is your vehicle listed for the Cruise control recall?
JMC
Old Jun 20, 2006 | 07:12 PM
adrianspeeder's Avatar
Yeah was this a ford dealer? If you havent had your CC safety switch changed under recall yet, and the dealer doesn't have the new part yet, they just tape off the sensor deactivating the CC.
Adrianspeeder
Old Jun 21, 2006 | 12:41 AM
well it wasent the dealership, it was just some hole in the wall garage, paid 150 for it to be installed, well where is the output shaft speed sensor???? im not very motor person.... where is this and what does it look like
Old Jun 21, 2006 | 02:20 AM
pjb999@yahoo.co's Avatar
Hmm methinks you should bite the bullet and take it back to the garage, and ask them to check all the connections - explain clearly that the CC worked before - you could mention the possibilities listed here, but if you're a novice, and even if you're not, you shouldn't be doing a job someone else was supposed to get right, IMHO.
Old Jun 23, 2006 | 01:12 AM
well anyone help me finding the plug that guy thinks its disconnected i have no idea where it is
Old Jun 23, 2006 | 09:19 AM
JMC's Avatar
JMC
25 Year Member
The OSS is located in the extension housing of the transmission. Get under the truck and look at where the driveshaft enters the transmission. That part is the extension housing. On the driver's side there is a sensor that measures the speed of the shaft. The plug may be either not connected or damaged. The other plug is on the brake master cylinder. You can't miss it. Does the horn work? The horn relay shares a common ground with the CC.
JMC
