m5od 5 speed swap
m5od 5 speed swap
I have a 1999 f150 2wd with 4.6 engine,3.55 rear gears and m5od 5 speed.The reverse ratio is too high for backing up with a loaded tailer.One idea is to swap out with a ZF5 5 speed trans.I know these trans where used in f 250's behind 5.4's.And had a lower reverse ratio.The question is will the ZF5 trans physically fit in the f 150 chassic behind my 4.6.Or does anyone have any other options to resolve the problem.But I don't what put in lower rear gears
