1995 F150 4x4 manual transmission--can't get it out of 2nd gear
More info would be very helpful but just to take a stab at it, the truck has probably got a lot of miles on it and the shift linkage is probably worn. If the pins and stuff in the top of the tranny get worn or work thier way out then I could see how they might bind the shifter up. A worse scenario would be something interal to the trans. Could be a broken shift fork or something.
More info and good luck.
Truck has 115,000 miles on it. It has had regular maintenance since I bought it--last serviced in March of this year. The gear shift won't move at all, whether the engine is running or not, whether the clutch is in or out. We tried rocking the truck and still can't budge it.
Looks like it's time to call in the professionals.
Thanks for the replies!
That sounds like a linkage problem. I would try to pull the top off the tranny and see if I could tell what was binding it. I haven't done one in a really long time so I really can't give you any direction as to how to do it but any chilton or haynes manual should probably give you that info.
Anyway, good luck and I hope you get it taken care of.
when you start your truck...is the clutch in? I had this thought your clutch rod that comects to your pedal maybe binding...Iwas thinking the clutch was locked on to the fly wheal and not allowing you to change gears......poss throw out bearing as well...under the tranmisson check the drain/fill plug to see if ithe fluid level is correct. you should be albe to manualy move the gears if you disconect the shifter.
on
You most likely have the M5OD-R2 tranny. It is a relatively easy tranny to service. The shift forks are in the cover and once the cover is off you can see into the tranny. It may be a simple case of over extending the shift lever locking the lever in the second gear position. Try removing the lower shift lever, if it is stuck odds are that is what happened.
regards
JMC
regards
JMC
