Older E4OD Question
Old Nov 20, 2004 | 02:51 PM
Unlawful's Avatar
Registered User
Older E4OD Question
Just wondering about a 96 4x4 5.0 I have, the TC is just about toast and I have an 85 - 86 5.0EFI AOD 2WD trans , just wonderin if the TC will fit my 96?
Old Nov 20, 2004 | 03:59 PM
dirtyd0g's Avatar
No, you need a 4 stud e40d converter. Aod converters had the wrong spline count,stack height, twin input shafts, and they did not have a lockup clutch.
Alan
Old Nov 20, 2004 | 07:04 PM
Unlawful's Avatar
Registered User
Great, thanks
Old Nov 20, 2004 | 07:08 PM
Unlawful's Avatar
Registered User
Acually another question about that is, my E4OD has a smaller pan than others I've seen, so there must be two different types of trannys in these trucks, but do both TCs match each other?
Old Nov 20, 2004 | 09:03 PM
dirtyd0g's Avatar
There are old style and new style pans but they can be interchanged with the right filter. If the converter has 4 short studs it will work but you really want one with straight fin angle and 4 short studs. One with rectangluar lugs is best because it would have the updated lockup piston inside it.
Alan
Old Nov 21, 2004 | 08:45 AM
Unlawful's Avatar
Registered User
I just did some reading and apparently this truck will most likely have a 4R70W trans and not a E4OD.... The 4R70W has a pan length of just under 15 inches witch the E4OD has a Pan length of 20 inches, is this right? and will both TCs be the same?? The article I read is at http://www.baumannengineering.com/e4odinf.htm any help would be great as I would like to have this thing replaced this week
Old Nov 21, 2004 | 09:44 AM
dirtyd0g's Avatar
No you need a converter from a transmission that is the same.
