Question from a new member
Old Jan 27, 2003 | 06:01 PM
TN F150 fan's Avatar
Question Question from a new member
New member here.
I'm glad to be on board but I have a question.
I have a 1997 Ford F150 with a 4.6 and the tranny code is a U. The tranny seems to rapidly "bounce" in and out of overdrive at 1700-1900 rpm. Is this something that anyone else here has experienced and what did you have to do to fix it? Thanks.
Old Jan 27, 2003 | 07:18 PM
Old Timer's Avatar
Hi Tn Welcome!
When i first got my 99SC 4.6L a/t (4R70W) it did same thing.
I think same tranny in your truck. Apparently fairly common at the time...dont know about newer models?
After i installed the schip...it did change way a/t shifts...still drops out of o/d...just not as much. Check out computer bd.
Read/search what others have done to change way a/t shifts. Lots of info. here.
Good luck...OT
Old Jan 27, 2003 | 08:22 PM
medic's Avatar
This sounds more like your truck is umlocking the torque converter. I'm assuming this happens on a slight incline. When you think your truck has shifted out of OD into 3rd push the OD button & see if it shifts down again.
If what I described is what is happening, don't worry...it's perfectly normal.
Old Jan 27, 2003 | 09:02 PM
Thanks for the replies. It actually does the same thing if the overdrive is on or off. It does it when going up a slight incline. What concerns me is that I never really noticed it with this frequency over the first five and a half years or the first 40k miles I owned the truck. It seems to be perfectly normal other than this.
Old Jan 27, 2003 | 10:07 PM
medic's Avatar
Okay, in that case it may be torque converter shutter. This was very common in the 97+ models with Mercon III ATF. It normally happens between 35-45 mph, but can happen at other speeds. The simple fix to this problem is to completely replace all the ATF with Mercon V. This will normailly clear up any TC shutter within a few hundred miles. I think this can be done with a transmission flush too, but I'm not sure.
Old Jan 28, 2003 | 09:08 PM
danny owens's Avatar
trans codes
The transmission codes are:
M — Manual, 5 speed, overdrive M5OD.
U — Automatic, 4 speed, 4R70W.
E — Automatic, 4 speed, E40D.
Old Jan 29, 2003 | 07:54 PM
Thanks for the info, everyone.
Old Jan 29, 2003 | 09:37 PM
suvdrvr's Avatar
If you're interested in changing the fluid yourself, this site could be a help.
http://members.shaw.ca/pferlow/transmission_oil.htm
Old Feb 1, 2003 | 07:54 PM
Just asking for an opinion. I regularly change my own oil and spark plugs on different vehicles and other simple things. This fluid change with the torque converter drain procedure sounds a little more complicated however. I don't want to bite off more than I can chew. Any advice or opinions from someone who has done this previously?
Thanks.
Old Feb 1, 2003 | 09:20 PM
medic's Avatar
If you can change the plugs in your f150 4.6 then you shouldn't have any problem with this. I can be a bit messy, but if you don't mind getting dirty go for it. Jack stands can help with the job, but I'll warn you, my '97 f150 4x4 has a cross member that prevented me from dropping the back of the pan first. Considering I had the front jacked up I thought gravity would help if I dropped the back first, but just ended up making a big mess when the fluid ran down the cross member to the frame.
Regardless, it's fairly easy, just be ready for a mess. The good news is if you do it yourself you know its done right.
And I almost forgot...DON'T use the cork gasket that comes with the filter! Reuse the Ford gasket.
Good luck
Old Feb 2, 2003 | 08:36 AM
Mark Kovalsky's Avatar
Try this method. It may be less messy.
http://www.ford-trucks.com/articles/...hangingatf.php
It covers the E4OD, 4R100, and 4R70W.
Old Feb 2, 2003 | 03:38 PM
suvdrvr's Avatar
Is there no danger of damage to the tranny if you drain the fluid by using the engine to pump the fluid out with the tranny in neutral as described in the proceedure referenced by Mark?
Old Feb 2, 2003 | 07:34 PM
B-Man's Avatar
Cool
If this guy is a "Ford Transmission Engineer" like he claims he is, there is nothing wrong with Mark's advice.
Great Transmission Info Here
After reading some of the info here, it seems like a good cooler is the single most important item for a tranny...
