Torque Converter Drain
Old Jan 6, 2003 | 08:36 PM
expy69's Avatar
Question Torque Converter Drain
It's time for a trans oil change. (Again)
How do you get the converter drain plug to be visible?
Must be an easier way than cranking the motor!@#$
Thanks in advance,
john
Old Jan 6, 2003 | 09:49 PM
Mark Kovalsky's Avatar
Put a socket on the crankshaft bolt and turn the engine with a breaker bar.
MAKE SURE THE KEY IS *NOT* IN THE IGNITION!!!!!!!!!!!!!!!!!
Old Jan 7, 2003 | 07:55 PM
TexfordD's Avatar
and have a good ....
creeper to slide back and forth on
Old Jan 7, 2003 | 08:09 PM
JBRIII's Avatar
use an 18mm socket on the lower pully nut. turn until bolt is visible in inspection hole. I did my brothers last month and I could keep my eye on the hole and trun the socket wrench at the same time. But his wa a 4x4 and had a little more room underneath to move around into position.
John
