Towing Question
Old Apr 4, 2002 | 02:29 PM
wengerda's Avatar
Registered User
Towing Question
When I bought my 2002 Ford F-150, the red side window sticker shows on the options that I have 6500# GVWR Package Electronic shift 4X4
Does that means that is the max towing capacity for my new truck?
2002 Ford F-150
5.4L V-8
3.55 ratio limited slip axle
class III towing package
Old Apr 4, 2002 | 03:28 PM
CanadianSCrew's Avatar
No the GVWR is the carrying capacity of the truck. The weight of the truck and maximum cargo equals 6500. The towing capacity will depend on cab configuration engine 4x4 wheel size etc. I have an 6600 GVWR and an 8000lb towing capacity.
You may have a towing capacity of around 8000Lb assuming you have a supercab with 16" wheels. I have a supercrew so I lose 300lb off the towing capacity for cab weight I guess but it is 2 wheel drive. You lose 300lb for the 4x4. !7" wheels will change the drivetrain ratio and you lose 500lb.
To make things more confusing there is also a gross combined weight and on my truck of 13000Lb
Old Apr 4, 2002 | 03:31 PM
wengerda's Avatar
Registered User
Great information. Thank you.
Old Apr 4, 2002 | 03:48 PM
BeastRider's Avatar
No GVWR means Gross Vehicle Weight Rating. It means that the weight of the truck, plus accessories, plus luggage, plus fuel and other fluids, plus trailer tongue weight, plus passengers cannot exceed 6500 lbs total.
Old Apr 4, 2002 | 03:51 PM
wengerda's Avatar
Registered User
Well now I am confused, but it is okay, my trailer/boat with fuel and accesories weights approximately 3500lbs.
I should be okay.
Old Apr 4, 2002 | 03:59 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Thumbs up
At 3500lbs you are well within your towing capacity. You could bring 8 to 10 bikini-clad women! You won't even know it's there, performance wise.
Which means, check the mirror occasionally an make sure it still is.
Old Apr 4, 2002 | 04:00 PM
wengerda's Avatar
Registered User
Thanks, I will make sure I do that.
Old Apr 4, 2002 | 04:13 PM
IAmGeeky's Avatar
Rer's are a different story
A fith wheel will max out your drive axle rating WAY before you reach your towing cap.
Just thought I'd throw that in because it almost happened to me with a 6400# GVWR 5er.
The king pin adds around 1K to my 2220# drive axle weight. My drive axle rating is 3500#. I have heard that you want head room of 10-20 % so I will be cutting it a little close.
Old Apr 4, 2002 | 08:30 PM
TRK's Avatar
TRK
You can check the specs on your truck here. Just scroll down to trailer towing, find your model and gear ratio and look across.
Tim
http://www.ford-trucks.com/specs/2002/2002_f150_1.html
Old Apr 4, 2002 | 09:56 PM
FamilyRide's Avatar
It can be confusing can't it? You can stay within your combined yet exceed your GCW, or exceed your towing and still be within your combined or GCW or......nevermind, I'm getting confused all over again.
Yes, 3500 lb's is a breeze! I do over 7000# without a problem.
