LS Axles
Old Apr 7, 2001 | 10:42 PM
MG's Avatar
MG
Question LS Axles
Hello all,
I am getting ready to order a 250 SD Crew. I will be towing a TT (to be purchased in the near future) with GVWR of between 6500 to 7000 lbs. After reading a lot of great postings I have been reassured that the V10 will be more than adequate for my needs. What are the advantages of the LS as opposed to "regular" axles? What is the advantages/differences between the 3.73LS and the 4.10LS? Dealer recommends the 3.73LS.
Pros and cons??
MG
Old Apr 8, 2001 | 01:03 PM
Ian N's Avatar
Post
The LS will keep you from spinning one wheel in a muddy campsite and going nowhere. You don't say if you have a 4x2 or 4x4 but the LS will help in either case and the option is cheap.
As far as gear ratio's go, you should get at least the 4.10 and maybe even 4.30. Don't even consider the 3.73's - you will never get the engine into its power band at highway speed. The idea is to get the engine revs close to the torque peak at highway speed, so that the engine has lots of power for towing.
The 3.73's make sense for the PSD, since its torque peak is at about 1800 rpm but the V10 has to get to 3000 rpm for its peak.
Ian
99 Expedition EB
5.4l, 4x4, 4.10 LS
WMS Tube, Bassani Cat Back Exhaust, Superchip Flipchip
Old Apr 8, 2001 | 05:01 PM
Tina's Avatar
Thumbs up
Axles offered with the V10 are the 3.73 & the 4.30
Get the limited slip, just remember that it's called "limited" for a reason. If you really think your gonna need more than don't get LS and add on an aftermarket one later. This is a much more expensive route and for most people, Ford's version of the limited slip works just fine. That's what I've got on my truck and rarely do I need more than that. (sometimes I would "like" more but I've still managed to get myself out of sticky situations with what I've got )
2k F250 CC SWB 6 speed 4x2 Diesel XLT Super Duty, Woodland Green
Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, rear privacy glass
TT Pkg, Class IV hitch, sliding rear window, running boards, mud flaps
265/75/16 AS OWL tires, am/fm/cassette/cd, rechargable MagLite
Clarion APA 5240 amp, Memphis speakers:Components front, 5x7 rear, 10"sub
SuperChip, Stepshields, Ventshields on windows, rubber bed mat
rugged liner bedliner on tailgate, quick disconnect jumper cables
unaFORDable (decal on tailgate) Western Diesel Turbo Brake (whoa boy)
Finally gauges!!: Pyrometer & Boost on the A-Pillar mount
Old Apr 8, 2001 | 07:34 PM
Y2K 7700 4x4's Avatar
Post
Like she said.
Old Apr 9, 2001 | 04:31 PM
MG's Avatar
MG
Post
Thanks for the help.
I'm still decideing between the 4x2 or the 4x4. I probably wouldn't use the 4x4 often but I'm sure it would come in handy when needed.
MG
Old Apr 9, 2001 | 09:53 PM
Post
The decision to purchase a 4x4 is more of an "cuz I want it" than "cuz I need it". If you've never been stuck with a 4x2 in the application that you're intending for your new truck -- then it's more of a "want" issue.
If kept for a few years, the 4x4 will hold it's value -- but if kept for a long time, it can nag you with simple but high-cost maintenance.
4x4's are high-value in some parts of the country -- and add no value in others. A trip thru the want-ads will give you an indication.
There is virtually no penalty for gas mileage for a 4x4 -- unless you're in 4wd -- where it's very noticeable -- however, if you need 4x4, then it doesn't matter since you'd be sitting home without it.
I got it simply cuz it's cool!
Enjoy,
Y2K™ Jim - N8JG@Hotmail.com
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
