hitch ball drop??
Old Nov 27, 2007 | 07:22 AM
WP Bruce's Avatar
hitch ball drop??
All,
what would be a good drop amount for the ball on my truck:
'07 XLT 4X4, 2.5" level, 32" tires
i've been looking at other trucks around town and see anywhere from 2" to 6" or even more...
i wont be towing that often but we will be moving soon and will rent a uhaul flat-bed trailer to drag the Harley to our new home.
thanks in advance!
Old Nov 27, 2007 | 08:18 AM
Colorado Osprey's Avatar
Most bumper pull trailers have a tongue approx. 16" off the ground. By putting a ball mount that located the top mounting surface of the ball mount about (not the top of the ball) 16" will make 90% of the trailers produced almost perfectly level. If you will be towing heavy loads that will sag the truck you might want to get a ball mount that locates the ball an inch or two higher.
So grab a tape measure while the truck is on level ground and see what you need to get the ball mount at 16".
Old Nov 27, 2007 | 08:32 AM
APT's Avatar
APT
How about an adjustable ball mount? Can be had for about $50.
Old Nov 28, 2007 | 06:42 AM
WP Bruce's Avatar
'preciate the info y'all!
thanks
Old Dec 1, 2007 | 09:37 AM
gixxerjasen's Avatar
I'm currently looking around for the part that goes in the receiver of the hitch that comes with the towing package. I pulled my trailer up behind the truck and it looks like it needs zero drop or lift. Trouble is, all the ones I've seen have at least a 2 inch drop to them.
Hmmm, maybe I can justify lifting the truck to the wife. Sorry honey, the trailer's gotta be level, so I need this lift kit and bigger tires to make it work.
Old Dec 1, 2007 | 10:20 AM
A 2" drop ball mount installed upside-down is a zero.
They aren't just drops, they can be used to raise also.
Old Dec 1, 2007 | 12:35 PM
My draw bar is reversible - it can be a 2" drop or a 3/4" lift. On my truck, the 3/4" lift is perfect for most utility trailers. If zero looks right, a 3/4" lift would be right when you load a few things into the bed of the truck.
