towing with the 4.9
towing with the 4.9
Would i have problems with towing a (i think) 20" camper with the 4.9 I6? that is other than not being able to pass anybody
. my friend offered to let me use his camper for a weekend
96 f150 4.9l 5speed 4x4
Thanks!
. my friend offered to let me use his camper for a weekend96 f150 4.9l 5speed 4x4
Thanks!
about how heavy is the 20' camper? do you have e4od, or 5spd? what rear gears do you have? do you have rear LSD? i've towed a 6,500lb tractor on a 3,000-4,000lb trailer = 9,500-10,000lbs with a 96 4.9L 5spd 3.55s LSD, that truck was working!
Originally Posted by ford_model_a
Would i have problems with towing a (i think) 20" camper...
But seriously...
I've towed a 30' travel trailer several times, and you have to be prepared & practise, but the engine can certainly handle it. I've also towed more than 10Kip.
Originally Posted by Steve83
Well, 20 inches is pretty small - I doubt you'd even notice it back there!
But seriously...
But seriously...
Look up the axle code on the door plate.
https://www.f150online.com/forums/sh...d.php?t=276509
Air the tires to the maximum stamped on the sidewall.
still have no idea about the weight i dont have access to it and my friend is out of town....
4spd w/ overdrive -- 3.31 gears -- open differential
What do you think?
also thanks for the help getting all the info GLC
Well, with the Mazda tranny (M5OD) - if thats what you have - the towing limit is officially 3500#. However, I believe ManualF150 has towed a lot more with his V6 and Mazda 5 speed. The trans code on the door is M. It's gonna be a real dog with those 3.31's. If you aren't going to be in mountains you should be okay, take it real easy on the clutch.
https://www.f150online.com/forums/sh...d.php?t=211867
yah a friend of mine asked me to pull her trailor (just the back half of an old f350 every morning to go pick up produce for her produce stand... and fully loaded with 3000 ears of corn and other random produce it was really bad getting up to speed, makes me wish i would have gone for the other f150 i was looking at with the 5.0 auto
oh well i think im going to try pulling the camper anyway
thanks for all the help guys
What do i do to prepare? anything to the accual truck?
the offical towing limit is...
...with a mazda tranny. but with 3.31's, it aint gonna be too swift...
